RCU Forums - View Single Post - Paint compatibility
Old 09-21-2022 | 08:14 AM
Navy_Flyer
Default Paint compatibility
I was very lucky to find a few cans of Monkote LustreKote at the local hobby shop. Had been there obviously for quite some time, they had a layer of dust on them. Anyway, bought two cans of Jet White and one can of clear. In painting my latest project, I used Rustoleum white primer, sanded between coats. Put down the base coat of Jet White and it turned out fantastic. For the trim color, I could not find any 'fuelproof' paint (for nitro) so I sprayed Rustoleum color. Turned out beautifully. Then my thought was to fuel proof the Rustoleum by spraying the LustreKote Clear over it. After waiting for the Rustoleum to cure for 48 hours (as it says on the can), I sprayed a light coat of clear over it. Waited 5 min, and sprayed another light coat. Looking good. After another 5 min, sprayed a bit heavier coat (as it is instructed on the can). Set the plane aside to dry. Went back to look in about 30 min - and the entire color coat had wrinked/alligatored. Arggggggg! I had to wait a couple of days for the clear to cure, then sanded it all off - what a royal PIA. Re-sprayed with Rustoleum color and it is back to looking OK, but not perfect - so I am saying it now has some 'character', but I am still pissed about it.
So fair warning - if you still have any MonoKote LusterKote laying around, it's excellent and looks terrific - but is not compatible with Rustoleum. I should have done a scrap test first!
AFTER
After wet-sanding.
BEFORE
