Originally Posted by
jerrybern
I am using a Cortex gyro in my 1/4 Vampire,with a Futaba 10J radio.I have it on
channel 9 using a 3 way switch.When I use it the up postion shows yellow, middle red and down green.I set the travel to 30 and 20 % on the travel limits.My question is It responds very slow to any movements, is this normal? This is my first gyro so I don't know what to expect.
Jerry B
What you're seeing is probably right however I would move it from the switch to a rotary or slider and fly the model crosswind as fast as you are ever likely to fly it while turning the yellow gain up slowly until you're happy with it or the the surfaces start to oscillate then wind it back slightly. Then when you land check the the % travel you have wound in and then move the channel back to the switch to a 3 position switch and program in the same travel. I don't use the heading hold so I always wind that back to zero incase the switch inadvertently gets moved.
