RCU Forums - View Single Post - 2 stroke and 4 stroke fuel
Old 10-17-2022 | 08:00 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
And FWIW - I mix by volume, but I measure out a small volume and weigh it. Typically 1 fluid ounce (about 30mL). Then it’s just a matter of doing some math to multiply the volume desired by the weight to get the weight of the entire volume being measured. Ambient air temperature influences the density of the fuel components, so weighing the components before mixing will give the most accurate ratios.
