The Sky RC/ Xicoy weight load cells will help with larger models determining what the c/g actually is as you change ballast along the established moments calculations. Key word is calculations. As a full scale mechanic tasked in weight and balance specs, it takes allot of calculations and layout to set it up properly. It seems as if allot of sales in these products have buyers remorse when they try to use them and not comprehending all the layout of level and data points to establish moments and proper c/g location.
Id like to get these loads cells at some point as my models get 30+lbs............
