Originally Posted by
Jeff489
They made 2 versions of the 2 motor two gearbox black cap gearboxes, the original one, with an extra set of gears and a slider switch (to manual shift the gears) that was two speed, and the later single speed (current version) that simply had the extra gears removed.
You sure those aren't aftermarket ones? I know of them but have only seen them on German Tank specialized aftermarket sites.
Jeff489
Also not on the list are the gearboxes (assembled by modeller) which are 2 motor two gearboxes (used in the Sheridan and Centurion).
- the revised 2 motor 2 gearbox one
