I assumed your problem was the telemetry but that may not be the case. I recently had a problem with a SR10 receiver with no output, it ended up that I put the receiver in self test without moving the sticks to complete the calibration. I would suggest disabling the stabilizer and get the radio system installed first then work with the stabilizer if you indeed plan to use it. Also note that channel 10 works differently in Quick mode and Conventional modes. That fact cost me a scratch built 30% Piper Cherokee on the maiden flight.
