Set the midpoints as close as possible mechanically with radio trim at zero and endpoints at 100%. Then fine tune everything using the radio's trim and endpoint settings on the dual rate HIGH setting. Finally set the dual rate LOW settings on the radio.
In short: MECHANICALLY first, ELECTRONICALLY second.
Glenn
