ARTF: Custom Giant Twin Engine Stik 112.5" WS
OL: 82.0"
OW: 112.5" (3-piece wing with TNT wing tubes)
Centre Section: 36.5"
Outer Wing Panels: 38.0"
Dry Weight: 25.0 lbs.
Time to list another RC aircraft, with the sale of my custom Giant Twin Engine Stik. We all know how well a Don Anderson designed Stik flies, regardless of size or even how its powered! Learn how to fly a twin engine aircraft without risking your prized scale twin engine project! Here's what's included in the sale:
-Don Anderson Giant Stik plans enlarged/modified by Roger Marshall for twin engine operation.
-Three-piece wing set-up allows transportation of the Stik on its own gear, only one servo to hook-up on each outer wing panel at the field!
-twin DLE-35RA rear exhaust engines each w/Bowman rings & Tech-Aero IBEC.
-Pilot 32oz. main tank with Dubro 4 oz. header tank in each nacelle.
-both 4.0" 3-blade & spare 4.0" 2-blade aluminum spinners.
-four Turnigy Laminated 17" x 8" 3-blade props.
-Valley View enlarged Walbro carb instead of DLE version & fuel dot.
-Engines bench run only to sync both high/low needle set-up.
-CB Associates 4.5" main & tail wheel assembly.
-Combination Monocoat & Hangar 9 red/white covering used on top surfaces & fuselage. High visibility black/white/red checkerboard on underside of wing. German WW-1 Black crosses added with "Skull & Crossbones" on rudder.
-TNT aluminum main landing gear with Bennett Built 1/4" LG reinforcement system for those "less than perfect" landings!
-Spektrum AR20310T 20 channel receiver with AS3X gyro module and three satellite receivers.
-two Electro Dynamics 6.6v 2,500 mAH Life batteries w/HD switches.
-Futaba S-9202 servos w/aluminum servo arms on ailerons.
-Hitec HS-5645MG Digital servos w/aluminum servo arms on flaps.
-Futaba S-3001 servos w/aluminum servo arms on throttles.
-Savox SC-0251 servo on rudder/tail wheel steering.
-all required servo/battery wiring le ads and ED-Klik 4-servo connectors utilized on both left & right wings and to receiver.
-HD Titanium servo linkages & HD horns on all flying surfaces
-aircraft has not yet flown and as usual, check your C/G first, and good to go!
Over $2,600 invested, but my loss is your gain. Cash sale at time of pick-up in Simpsonville SC. Plane is too large to ship, so please don't ask. More projects for sale will be posted as time permits, so stay tuned!
