Originally Posted by
Skunkwrks
I had three servos that died in the flaps position, one with no servo arm attached, the second was sitting idle, then poof, three one died just prior to maiden.
Same manufacturer on all three and they have refused to do anything after t was brought up to them .
These are Pilot factory pre-installed servos from the turbine-ready version. This is my second Pilot 2.2 predator. First one never had a servo problem in several hundred flights. This servo worked again after it cooled down. it was the improperly established flap hinge that over-worked the servo.
