A good example of the reduced quality in modern day DLE engines is if you get to look inside a K&B sportster engine they are ported the same way as newer gas engines they just have a couple channels cut out of the cylinder for ports and the sleeve only supports the piston part of the way around . I'm sure this method is cheaper to manufacture but I prefer a higher level of craftsmanship in engines I choose
