I flew the aviation designs F117. 1- 1/2 flights. It went in with heat problem.
The tail was used as elevator only. The full scale pics showed shots with both
The tail in use and some without. First flight was a piece of cake, no problems.
Make sure there are no heat leaks into the fuse. The tail pipe does restrict flow.
Jack
