f117
Old 04-08-2015 | 09:50 PM
Default f117
hi guys couple question about the f117, what electronics/gyros would you use to make this flyable? also would you put rudder only v-tail like the real thing or make the tail control pitch instead of elevons to make it easier to fly without 4 laptops plugged into it?
Old 04-09-2015 | 02:01 AM
grbaker's Avatar
My Feedback: (29)
Bob Fiorenze used to fly the Yellow Aircraft F-117 very well without 4 laptops. And that was at least 15 years ago.
Old 04-09-2015 | 05:41 AM
FalconWings's Avatar
My Feedback: (57)
What gary said. Bob Fio had no problems.
Smokin Joe McBride had a much bigger one. That one probably did have 4 Laptops though. You may want to touch base with him.
David
Old 04-09-2015 | 06:06 AM
My Feedback: (49)
It will fly fine without gyros, etc. Like any other delta it's very stable with a forward CG. The real one has a rearward CG to make it more maneuverable and therefore requires computer augmentation for stable flight.
Old 04-09-2015 | 11:13 AM
i see thannx for the imputs guys.
Old 04-10-2015 | 07:07 AM
so if i put my cg forward i dont need gyros and whatnot?
Old 04-11-2015 | 04:55 AM
My Feedback: (49)
Just put the CG where the manufacturer recommends. From your questions it sounds like you need more modelling and jet experience before tackling a project like that.
Old 03-22-2023 | 07:03 PM
My Feedback: (169)
I flew the aviation designs F117. 1- 1/2 flights. It went in with heat problem.
The tail was used as elevator only. The full scale pics showed shots with both
The tail in use and some without. First flight was a piece of cake, no problems.
Make sure there are no heat leaks into the fuse. The tail pipe does restrict flow.
Jack
