Thanks for the reply Ron. I'm thinking to use this drive to replace the old Dumas stuff along with adjustable trim tabs and turning fins. **** can't post images yet. It is a one piece 1/8 out rigger style set up with the stuffing tube/shaft exiting at the very bottom of the transom rather than through the hull. Will that work and can you suggest an Octura prop to suit the O.S. .10 with such a set up?
Kind regards
