So is a dremel cutoff wheel the best thing to use for trimming the canopy and the cockpit tubs? Get it close with the cutoff wheel and then fine tune with some sanding blocks?
I’ve sort of been dreading that part of the build but I’m getting to the point were I need it to CG the plane and figure out battery placement.
