Correct, this is the new version board with sound. Not sure if it has a drag brake or not, I will have to research that. It stops no problem but when attempting to go forward again it just sits there and makes the sounds (speaker) like it is going. And there are times if it is reversed after stopping then forward it actually moves….. other times it doesn’t reverse or forward. I might end up ordering another truck anyway and also another sound board like I have to see if the other one I order has the same issue
