wing problem
I am working on a Somthin' Extra. Well, now that I have both wings built I've noticed that one of the wings has pulled out of form meaning it's not streight. I've had to sand a lot to get it to fit to the profile of the fuse and ended up adding a couple of small balsa peices on the inner stringer tomake the fit and not sand any more of the plywood stringer off. This being done, I've hat to add a 1/4" section of wood to the aileron. The leading edge of the wing doesn't seem to be pulling forward that much though. How it this screw up going to affect the handling and aerodynamics of the plane or will it?
