RCU Forums - View Single Post - CARF Ultra Flash Evo build thread +
Old 05-08-2023 | 09:06 PM
  #610
Dave Wilshere
Originally Posted by camss69
Can you do the string method with the single piece wing on the UF?
Just lightly tape it across the wing surface on the balance point, put the wing on (just tighten enough to trap the string-cord) if you over tighten you will mark the wing surface, then lift….
Again 90% of jets the balance changes with fuel, so unless we all use measured volumes of fuel it’s a close point you are looking for.
Flying with your set up is the only way to perfect the balance required
D
