Well, well, well been playing the whole afternoon with running my engine, there is not much difference between a medium and a hot plug. The slight difference I did see was the every now and again the engine would cut out when using the medium plug. With both plugs the lowest rpm I can get is between 3~4k. I can get it lower but the engine is prone to cutting out and the vibrations are severe(mechanical harmonics).
