Is there any vacuum at the carb when you choke it by hand? If it run when you prime it then I would suspect some thing in the carb or back through the fuel system. Take the cover off the side of the carb that has the fuel reservoir and check for fuel . If no fuel there then the carb pump is not pumping fuel .
