RCU Forums - View Single Post - Trying to get DG1 and DG2 to work
Old 07-15-2023 | 12:04 PM
cpdouglas
Default Trying to get DG1 and DG2 to work
I have a 16IZ and I’m trying to get DG1/2 channels on my R7014SB to work.
I’ve set the system type to FASSTest 18CH and am using the default switch assignment
I see the on the servo monitoring screen the switches changing the state of DG1/2, but when I look at the signal pin with a voltmeter I see the voltage change from .2 to .4V on switching.
I’ve been unable to find much info on how exactly this is supposed to work. Maybe it’s changing impedance?
Any info on how I should configure the system to be able to switch using these digital channels would be really appreciated.
Thanks!
