Originally Posted by
thailazer
^^ It surely is! I just had an issue after 6 years of flying where the covering lifted off the bottom of each elevator surface, causing a nose-down pitch. Made it back to the runway but damaged the firewall. Easy fix and it is flying perfect again. The cover is so stiff that when it lets loose, it doesn't flap in the breeze but rather becomes a control surface! Might want to check that to keep your Tiger purring! Thanks for that post easy star!
Many thanks Thailazer for your reply and advice. I will definitely keep an eye on the covering of the Tiger 3 even though I've only had it a few months. I'm also thinking about getting the bigger Tiger 60 as I have a brand new ASP 91 fourstroke in a box and I thought that would be a good plane for it. I think you have also the Tiger 60 or maybe I'm wrong? If so, is it as good a flyer as the Tiger 40?
