RCU Forums - View Single Post - Prop Reamer
Thread: Prop Reamer
Old 07-22-2023 | 11:12 AM
  #52
Jesse Open's Avatar
Jesse Open
I use standard reamers and grind a pilot on the first 10-12mm. Made several, also make up bushings to allow using a smaller pilot in a larger prop hole.
Grind pilot hole on size, grind new cutting edges and reliefs on the reamer flutes. Easy to make pilot bushings as needed.
