RCU Forums - View Single Post - Scratch Built T-80
Old 08-16-2023 | 09:15 AM
lposter
Put my standard issue coat of gun metal on the hull and turret.
Managed to get some scratches on it so I will have to touch it up.
Th epoker chips in the last image are the wheels and idlers.
Then there was the track issue. The T-80 uses some weird double toothed track with a single row of teeth on the sprocket engaging in the middle.
The only two toothed track I know of is the Sherman. So I got some. Then I filed, ground, Dremeled and sanded off the chevron things. Then I made a little jig and drilled a hole in the dead centre of each link. Tedious work. The aim is not so much to produce a T-80 track, but to produce any track that works and that doesnt stink of Sherman.
Then the sprockets wouldnt fit correctly. So I ground off the back of the sprocket until I had just a disk of teeth left.
Then I adjusted the teeth spacing with a file. Then I mounted that disk between two steel "rims", checked that the "sprocket" was running true, then bolted the two "rims" together ending up with a rudimentary sprocket with a central row of teeth.
They need some finessing and a means of getting them on the drive shaft but that shoul dbe OK.
They engage nicely with the tracks at any rate.
The following 2 users liked this post by lposter:
Hackworth (08-16-2023), tankme (08-16-2023)
