I may have caused some confusion! This is what I have:
https://www.rctank.de/Panther-G-Jagd...tal-lower-hull
I intend to use these on a non-panther build as running gear. I have built swing arms. I need to mount these to a hull.
To ensure I have correct clearance between the overlapping wheels I need to know how far apart should I drill the holes to attach the swing arms to the hull.
To do this, it would be handy to have the swing arm to swing arm lateral distance for a panther.
To get this the simplest way is to measure the centre to centre distance of the swing arms axles or whatever on a panther tank.
But I dont have one.
So the question is....could anyone measure that distance for me ?
Im not really worried about the wheel diameter as once I have the centre to centre distance of teh swing arams...I can check that will work for my wheels.
I can of course just start making loads of test holes at various distances....but its tedious and is wating some of my materials.....
p
