Beautifull work Where do you keep your Magic wand? ha,ha .Are you going with Fabric and paint covering? Color scheme yet?
Do you think the LG will support planes weight or will you make the inner gear brace with dampining spring?
My Skybolt on hold for a few days while helping my little sister move to new home.
I did get the DLE 61 installed and test ran. Hope to lighten tail enough to omit adding ballast to engine compt. Thanks for posting plans. Vertical line from lower CG mark on plans to my top wing puts CG right where i figured it would be.
