RCU Forums - View Single Post - BJ Craft Anthem
Thread: BJ Craft Anthem
Old 10-19-2023 | 04:16 AM
  #71
barnowljenx
Originally Posted by YmeF3A
Yes I already saw that one on the internet and wanted to try it .
I now use the original from futaba but only nows how much amps you pull, voltage, and comsumtion.
the bad thing about that one is that you always have to rest it before you fly.
Do you also need to rest the unisn-e ( the one you use. )
Everytime when I set my transmitter on there is already 3000mAh -4000mAh used because of the flight I did before. So every time I turn my radio on I need to restart the telemetry. That just a little frustrating because sometimes I forget it.
The Unisense loses all the data as soon as you unplug the main drive batteries are disconnected! So, every flight starts off with the pack capacity you loaded into your Tx. There is another, slightly more expensive system, called the Unilog, that has a mini SD card in it and that records every flight for you to analyse off line on your PC.
