RCU Forums - View Single Post - Fire Tug - Shelley Foss Tugboat 36" Build
Old 10-22-2023 | 10:46 AM
  #80
birdo
Default Shaft Seals
I found Shaft Seals that will fit my Kort Nozzle shafts(5mm). Then I ordered some aluminum tubing for them to fit in, and cut it down to 1/2" tall. I'm going to drill a hole large enough to set the aluminum tubes at height, and then peanut butter epoxy them into place. I can use Teflon washers to shim them perfectly.
