RCU Forums - View Single Post - Fire Tug - Shelley Foss Tugboat 36" Build
Old 10-22-2023 | 11:08 AM
  #81
JS440
My Feedback: (10)
Originally Posted by Hydro Junkie
I was thinking the same thing. Some 1/16th aluminum would work fine for the arms. Just make sure it's 6061 or 7075 as most other types are too soft to hold up. Other types of metal might not work due to soldering/welding issues
You'd have to glue the aluminum on, which I wouldn't personally trust. I've used both brass and stainless, depending on what material the shaft collar is made of, and solder to suit. Stainless is of course preferred, but requires a much higher temp to get the silver solder to flow (and silver solder ain't cheap!)
