Well the wing got mated on the fuselage today went really well, little sanding but the fit was good and tight. Ran into a small issue with the right engine rail. Need to can’t the Fox Stunt 35 about two degrees right the nose narrows down about a quarter inch to mate with the nose and belly fillet. So the engine rails cut into the sides causing a fouling issue with metal engine mount. Needing to install blind nuts to secure the Fox. Ordered a Fox drill mount to accomplish this. Also the elevator control rod fit great after cutting the center cover assembly. Going to apply heat shrink on the clip to insure it will not come lose. All in all it’s doing pretty well.AJ
