I have just picked up a X60 to replace a P60 and the size difference is crazy. Let alone the 700g weight saving for the same thrust.
The ECU is also built into the engine cover so it means you can transfer the engine between models with a relatively cheap second engine kit. Just unplug and unbolt the engine and connect it up in the other airframe. No requirement to remove wiring etc
