Well I used linseed oil and got out my Air drill and drilled thru that knot. Got the blind nuts installed and applied epoxy to secure those blind nuts. Decided to do a reinforcement on the engine hard wood rails. Just to be sure they hold up and not fail tomorrow I might mix up some smooth and easy and coat the tank area, and install the Fox Stunt 35 and finish up the nose block. Next step is to remove the Fox and build the tank hatch it blocks into the nose piece and is secured by two wood dowels the rear is secured with two magnets. Reinstall everything and start this weight and balance computations. I’ve weighted everything. But I am hoping for a max to weight to be around 34 Oz. And looking for a tad heavy in the nose. AJ
