Looking at the Super Ringmaster plan. That nose piece is nothing like the plan, really high and the fuselage balance point is at the forward lead out wire. That’s the down control, just to see where she will balance. That nose block and bottom is not lining up. The thrust line is the center of the leading edge of the wing. But it ended up about one fourth of an inch below center of the leading edge. The good part is the center of the prop hub lines up with the lower thrust line an so does the horizontal. The rudder off set is one fourth of an inch, and the engine is one degree off set. That first flight might be interesting. The plan calls for a slightly heavy nose. I may install every thing except the belly plate and see how much weight I will add to the tail area maybe place it behind the wing in one fourth ounce increments toward the tail. Hoping for a TO weight about 34 Oz. I will load the fuel tank with 26%caster fuel and see how much it weights. The plan does not illustrate much. Just a few fuselage illistrations.AJ
