RCU Forums - View Single Post - Super ringmaster
Old 12-17-2023 | 06:55 AM
  #54
AJ Sun
Well last couple days haven’t seen much progress on the Super Ringmaster. Worked on the landing gear cover. And started the bottom cowl vent cut. With the engine installed with the aluminum spinner and empty fuel tank. Placing 1/4 ounce lead weight just behind the trailing edge of the wing created. A nose heavy plane. Next step will be adding weight to the out board wing. Plan and kit included two nuts that equaled just a little over one ounce of weight. To be placed on rib 10 of the outside wing. I omitted that and assembled a wing weight box I purchased from Brodak. Drilling several lead weights. I am hoping my balance will come out with a slight. Nose heavy condition in all phases. AJ.
