RCU Forums - View Single Post - Super ringmaster
Old 12-22-2023 | 04:28 AM
  #55
AJ Sun
Well last couple days I’ve been filling the nose piece Balsa. Trying not to use a plastic filler. The Sig is like a Tight Bond but sands really nice. I don’t know is other builders do this
,but I mix Balsa dust and Sig bond add just a bit of distilled water to thin and fill the cracks and imperfections. My next big step will be adding the top fuselage cover, And the vertical. The rudder off set? I will start with one degree. Between the engine off set of one degree, and the rudder, with the wing weight and balance set I think that will be enough. I’ve already added one ounce of weight behind the wing trailing edge. I’ve been reading posts on Stunt Hanger and our site. Never done this, but I am going to try it. I want to know what one ounce of 26% caster and 5 % nitro weights. I know what my Brodak 2.5 ounce classic tank weights. Kinda fun and interesting to do this. Although I never thought about it when I was younger! Lately I’ve been thinking maybe if I did that then, I would not have crashed so much! AJ
