Here are some VR startup instructions for Oculus VR:
1) Under the audio settings in PC, check the sound output device is Oculus headphones.
2) Connect your Ikarus RC Simcontroller to the PC and switch on your radio.
3) Boot up the Meta Quest headset.
4) Launch Oculus client software in PC. In the main menu under "devices", check that the Quest headset is connected. If it is not connected, go to "settings", then "beta", and restart Oculus. Then check again that the headset is connected.
5) Put on Quest headset. In the virtual menu, select "quick settings", then "Quest link", then launch air link. Confirm your boundary. Then temporarily remove headset.
6) In PC, double click on the icon "aeroflyRC10 (start in VR mode)", then select "fly". You should see VR mode active status displayed. Please note that after the first launch through your PC, the next launch of RC10 can be done directly from the virtual menu in the Quest headset.
