RCU Forums - View Single Post - Super ringmaster
Old 12-28-2023 | 07:29 AM
  #57
AJ Sun
Well finished up my handle mod had some longeron half round material off my Aeronca Champ build. Epoxyed after I cut the tack straight off just on the out side of the raco and Brodak handle. Then I took 1/16 round dowel rod and drilled two holes three inch apart and plugged the holes with the cowl. Now my hand fits really well and grips with out my hand getting pain in the palum. Next test is to try it out in the circle. Looking for a little over three minute flights. About ready to use the smooth and easy in the engine and fuel bay. I finished the top cowl smoothing to the nose contore. Really not impressed how the top cowl is attached. Two front dowel pegs and two magnets in front of the cockpit. Holds down the rear of the top cowl. Still need to cut the engine cylinder hole. And cut the access to the Venturi, for priming. My bottom cowl vent looks great and should help cool the motor on hot summer flights. Now I got to figure out why my I pad went to heavy print! Have a great New Year weekend guys and dolls. AJ
