EasyStar. I normally set the CG balance point at 42% of chord with no fuel. Note that the stock gear on the Tiger will have the tail fall to the ground. You need to bend the gear back to keep that from happening. Here is a video. (At the end at 2:50). that explains it on a Goldberg Tiger which Phoenix copied quite well! I don't think you need to add any nose weight.
