More info is needed for debugging:
Current at WOT (wide open throttle)
Same for RPM and battery voltage drop
Motor
velocity konstant Kv (expressed in rpm/volt, it has a massive effect, cubed, on current and power
drawn)
Note that Kv says nothing about max.continuous power, the motor in your toothbrush and the the motors in a 1:1 train can have same Kv.
With the above info you can try
www.rcgroups.com/electric-power-systems-13
Prettig weekend
Ron
• Without a
watt-meter you're in the dark ... until something starts to glow •
E-flight calculators •
watt-meters •
diy motor tips&tricks •
Cumulus MFC •
