Go Back  RCU Forums > Electric Aircraft Universe > Brushed/Brushless motors, speed controls, gear drives
Hobbywing platinum 120A v4 ESC cutting off at full power >
Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Old 12-25-2023 | 07:45 PM
gt_jumper's Avatar
Question Hobbywing platinum 120A v4 ESC cutting off at full power
Im new to electric planes, and was hoping someone might shed some light on a few bugs in my setup
My throttle response is docile and not snappy like i see in videos, and at full throttle the motor resets for a split second.
I have the following setup
*pilot RC 67" Laser
*4200mah 6s 70c pack
*Hobbywing platinum 120A V4 ESC
*disconnected BEC, running a separate RX pack
*Dualsky GA2000.4
*pilot RC 18x10 electric wood prop
Any ideas how to fix the slow throttle and the full throttle power cut?
TIA
Old 12-31-2023 | 07:24 AM
ron_van_sommeren's Avatar
More info is needed for debugging:
Current at WOT (wide open throttle)
Same for RPM and battery voltage drop
Motor velocity konstant Kv (expressed in rpm/volt, it has a massive effect, cubed, on current and power drawn)
Note that Kv says nothing about max.continuous power, the motor in your toothbrush and the the motors in a 1:1 train can have same Kv.
With the above info you can try
www.rcgroups.com/electric-power-systems-13
Prettig weekend Ron
• Without a watt-meter you're in the dark ... until something starts to glow •
E-flight calculatorswatt-metersdiy motor tips&tricksCumulus MFC
Old 01-01-2024 | 02:39 PM
gt_jumper's Avatar
Prettig weekend Ron
Hi mate, the GA2000.4 is a 400KV unit. I didnt put a wattmeter on it but i was betting on it being higher that 2400watt. The ESC was sent back, I tried programming it for my purpose using the optional programmer box and it did the opposite when back in the model. Then it wouldnt even read the ESC when i tried to reprogram it. The whole power train is being replaced with a Tmotor AM670 combo. I will be staying well away from Hobbywing.
