I never asked you to do anything, you offered to find an updated driver that would allow the datasafe software to work on a win 10 / 11 platform.
"Datasafe" is the JR backup software. Ver1.07 I have said software, the dongle and cable.
Part of the software suite is the comm driver driver that is no longer supported nor does it have a valid certificate as recognised by a WIN 10 or later PC. Hence it is seen as an "unsigned" driver by the OS.
I can do a workaround to disable unsigned driver check off on the PC. That then allows the data safe software to do a back up to the PC or back to the Tx.
I can configure parameters within the model config files and then load that changes file back to the TX.
Take care.
