JR 12X - mix to prevent nose gear turning when gear goes up
ok as per the title I am hoping somebody can advise on how to do this.
I am still using my JR 12X and need to program some sort of a mix so that when up retracts are selected the nose gear will not respond to rudder control.
thanks
cheers
P
thanks
cheers
P
BigBirdFlyer (04-11-2024)
Worked it out.
changed the mix master from gear to rudder
Set it up as a switch mix using gear as the switch
P0 = 0% L R
P1 = -100% L R
Also got rid of the aileron mix using AIL to AUX 3 and did it via the MATE function in the wing type.
P0 = 0% L R
P1 = -100% L R
I'm well aware of backing up though on the 12X it's no longer a simple exercise as I need to disable certificates in order to get the driver to work, do the back up then reboot. It's quite involved.
My Feedback: (41)
Ah it's one if those comp/geek things trying to find updated drivers. It's been a LONG time since I messed with this stuff on my. 12X but I think I still have a copy of that driver. It's a Win10 issue having to do with that provided driver is dated '95 and has no official Windows security signature so Win10 rejects it out of hand. It'a driver that converts a serial port on the tx to a USB port.
I'll upload it for you but since this server will not allow uploads of executable files, I'll have to change the file name from "_Setup" to "Zip".
After you download it, change the file name back to it's original "_Setup" and it should work for you I think. No dots, don't forget to put the "_Setup" file name extension getting rid of the the ".zip.zip" extension.
Best to avoid trying this for right now. It's a CellPro based driver and I think takes you to the CellPro website (which no longer exists) to finish installing the update. Let me look some more since this was done about three computers ago but I still have them. If I find just the bare drive I'll try to upload it here.
My Feedback: (41)
Sorry for the misunderstanding, thought I was doing a good thing trying to help with one model backup to the tx.......
I never asked you to do anything, you offered to find an updated driver that would allow the datasafe software to work on a win 10 / 11 platform.
"Datasafe" is the JR backup software. Ver1.07 I have said software, the dongle and cable.
Part of the software suite is the comm driver driver that is no longer supported nor does it have a valid certificate as recognised by a WIN 10 or later PC. Hence it is seen as an "unsigned" driver by the OS.
I can do a workaround to disable unsigned driver check off on the PC. That then allows the data safe software to do a back up to the PC or back to the Tx.
I can configure parameters within the model config files and then load that changes file back to the TX.
Take care.
Take care.
My Feedback: (41)
Spent the afternoon messing with an older computer having lots of the 12X/JR files. Got bigger confusion than before as I found about five different USB/driver files all named the same. I'm attempting to isolate them by date starting with the original Win file from 2006 when, IIRC, I originally upgraded from Win7 to Win10 which is where the problems started.
After reading your reply, I believe I'll drop the project.
