RCU Forums - View Single Post - Handle Suggestions
Old 01-12-2024 | 01:46 PM
AJ Sun
Well just seen RSM is no longer, been coating my Okie Air handle, boy it’s turned Cold. So I used spray Shellac. It fills wood pores. Also drilled a hole for my safety thong. On the down side of the handle. I will 400 wet or dry sand then add two more coats. shellac works great on gun stocks, that’s where I learned to use it mixed with fine saw dust to fill stock voids. Great stuff! AJ
