Thanks LLRCFlyer,
Below is what the seller which I purchased the plane from. Lived an hour and a half from me so I went and pick it up. Emailed him this pass weekend and this is what he came up with.
(1) GForce E480 Brushless Outrunner Motor (3530 - 1100KV), (2) GForce 40A Brushless ESC (XT60), (3) GForce 30C 1300mAh 3S 11.1V LiPO (XT60 Connector) x2, and (4) Gemfan APC Style 11 x 7 Electric Nylon Prop x 2. All of these items are plug and play...they work perfectly with each other.I would recommend 4 of Towerpro MG90D Digital Metal Gear Micro Servo. You can get cheaper plastic geared servos (still 9g) but metal gear so much stronger. You only need 2 I believe (no ailerons). You may need 2 servo extensions too.
As for the Kadet, either way going to be fun building this kit half scratch and half kit.
