RCU Forums - View Single Post - OFNA Spur Gear Question
Old 05-03-2024 | 06:54 AM
byggd
Originally Posted by bill_delong
I don't think the AE gears will be compatible, they are for 1/10 buggy with 48P and that's not going to do very will with a 1/8 rig even if those holes line up and you can get it to fit
MOD 1 gears are significantly different and far more durable
I couldn't find specs on most gears as far as center hole diameter or mounting screw hole spacing. "If" these mount up I will be happy, even if they don't last, at least I can have some more fun with my old truggy. I had no luck finding MOD 1 spur gears that look like they would mount up. Most use a 3-hole mounting or do not have an open center hole. Options are a bit limited when converting from nitro to brushless. Option 2 would be completely replacing the center hub assembly.
