RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
OFNA Spur Gear Question
Old 04-29-2024 | 07:35 AM
Question OFNA Spur Gear Question
I currently have an OFNA 18163 / 65T spur gear and I need to go to a lower tooth count. Info is hard to find with OFNA no longer producing.
I am seeing a lot of listings on EBAY but no tooth count it listed. Can anyone assist with a part number for a 50/55 etc with the same screw spacing as a 18163?
Don
Old 04-29-2024 | 04:53 PM
bill_delong's Avatar
OFNA was a distributor not an OEM, they rebranded cars from many different OEM's where the 2 most popular brands were HoBao and HongNor, both are still in production to this day, you just need to look for your specific chassis:
https://www.hobao-usa.com/product-category/rcparts/
http://www.rc-willpower.com/Cart/ind...y&path=487_495
You might be able to cross reference your part number on one of those sites!
Old 04-30-2024 | 08:32 AM
I knew about HoBao but HongNor is news to me, thanks to much!
I will do some research and see if there are a compatible models from one of these companies.
There is fairly large hobby store a few miles from out house. I may make a drive and depending on who is working that day, I may get lucky. :-)
Old 04-30-2024 | 08:55 AM
Didn't see any 65T gears on HoBao but found the following, does this look like your part?
G.V. Model 65T Gear #MV0651 [Mammoth] [Reely]
Old 04-30-2024 | 02:04 PM
The link doesn't seem to be working. I'm hoping to find a gear with the same mounting a the OFNA 18163 but smaller (less teeth). With the 18163, the mount I am using will not adjust far enough to install a drive gear.
Old 04-30-2024 | 02:50 PM
Willpower is located in China and takes a while to load, you need to be patient, just look for your car name to get the parts you need:
Old 04-30-2024 | 02:59 PM
I was getting a "page cannot be reached" but it is working now. As you said, just takes time. Here is the OFNA 18163 gear. I may be out of luck and have to run the OE steal with the OE smaller tires.
Old 04-30-2024 | 03:03 PM
Do you have the Ultra LX One?
https://www.ebay.com/itm/13387628461...2YVZ8AJ1YXSZ7B
Old 04-30-2024 | 07:56 PM
I bought it off ebay years ago and was listed as a Ultra MBX R2. The manual I found seems to support this.
Old 05-01-2024 | 08:33 AM
In that case I believe HongNor is the OEM and many of Ultra successors may offer compatible parts such as the spur I linked on post #8
Old 05-01-2024 | 10:49 AM
Cool! Thanks for the tip and all your assistance on this one!
bill_delong (05-01-2024)
Old 05-03-2024 | 05:47 AM
With your help and some research, I think I found an option! Will know in a week or so :-)
RC10B74 Center Diff Spur Gears, 72T/48P, 78T/48P
Old 05-03-2024 | 06:00 AM
I don't think the AE gears will be compatible, they are for 1/10 buggy with 48P and that's not going to do very will with a 1/8 rig even if those holes line up and you can get it to fit
MOD 1 gears are significantly different and far more durable
Old 05-03-2024 | 06:54 AM
I couldn't find specs on most gears as far as center hole diameter or mounting screw hole spacing. "If" these mount up I will be happy, even if they don't last, at least I can have some more fun with my old truggy. I had no luck finding MOD 1 spur gears that look like they would mount up. Most use a 3-hole mounting or do not have an open center hole. Options are a bit limited when converting from nitro to brushless. Option 2 would be completely replacing the center hub assembly.
Old 05-03-2024 | 05:34 PM
facepalm... I've posted links to 2 different sources for compatible spur gears, good luck!
Old 05-03-2024 | 06:32 PM
I very much appreciate all your help and I looked at every spur gear offered on both sites, 32 and 48P. None except the ones I posted even came close to the mounting needed to replace the current gear.
Old 05-05-2024 | 08:15 AM
After reading further about others that have done similar conversions, I see what you are saying now. The HongNor LX-1/2 EP parts may do the trick! I have ordered a spur / pinion gear and have high hopes! The pricing was a little better on eBay than the HongNor site (same shipping location).
Old 07-07-2024 | 07:42 AM
Default Covversion completed
With much help from others here and some additional reading I finally completed the conversion.
Old 07-08-2024 | 05:28 PM
SyCo_VeNoM's Avatar
nice job I have a jammin CRT that I converted ages ago using those same tires.
I stopped using it cause the tires would balloon up to where it looked like the truggy was on pizza cutters, and then it would flip due to air getting under it.
Old 07-09-2024 | 11:04 AM
The tires do tend to "stretch" at higher speeds :-) but I really like the additional ground clearance the give when bashing through rocks and dirt-clods. And the wheel offset make it much harder to flip and 60-70 % of the time it lands right-side-up. :-)
