RCU Forums - View Single Post - CARF Ultra Flash Evo build thread +
Old 06-30-2024 | 11:37 AM
  #802
737Driver's Avatar
737Driver
probably a little late in the game for pin removal tool idea, but I tried a jewelers common screw driver and it worked! The paper clip idea doesn’t work very well, bends to easy, but that jewelers screw driver has some rigidity to it and can pry open the lock that holds the pins in the AMP connector. Just a thought for you
Tom
Originally Posted by flaz
I'm not positive what size pins they have included in the Aeropanda set, but I suspect it's the same size I used. Digikey does offer several sizes, so you may be able to find a better fit depending on the gauge of wire used. Also, I still need to get the AMP pin removal tool. It's near impossible to remove the pins once locked into the housing without destroying them. Unfortunately the pin removal tool is rather expensive.
Oh yes, the gauge is 20-24, I'll fix the typo in my other post.
AEROSHELDON (07-25-2024)
