RE: HOW DO YOU CUT DIHEDRIAL
If you have a Kadet kit you will notice in the manual and the plans that there is a spar brace with the dihedral angle already set for you. If you follow the manual properly you will learn about the dihedral and how the wing center ribs have to be lined up....normally its half the angle of the dihedral for the wing.
