I'm attempting to use the Transparent Yellow Ultracoat and the instruction sheet that comes with it says I need to remove a backing, however, I didn't see any backing. Turns out the backing is completely clear (no bubbles) and it doesn't overlap the sides of the roll like Monokote did. In fact, it's somewhat difficult to separate from the covering. I found that placing a sticky piece of tape on the top (outside) surface and the bottom surface helps separate the backing from the covering.
