Did a few changes ,actually opened the canopy curve a bit to the front ,I think this way I can have only the canopy and top can as removable pieces and not need to cut the fuse ,it will be more rigid and will have a clean cut line of the two volumes this way. Rounded the aft section of the fuse a bit ,looks less ..sqare ish.Also redesigned the side air inlets.
