RCU Forums - View Single Post - ''NEW'' Pattern plane is looking for a name.
Old 09-27-2024 | 02:25 AM
Elias Sopeoglou
Originally Posted by FBW
Better Elias but I would still suggest you move the canopy further forward for true lift genaration at slow speeds.
This would also help with balancing the rotational inertia which will make the snap recovery easier.
At the last world championships I watched Christophe do the best Rolling circle of the event but snaps not so good........although snaps are very much open to interpretation ....[img]images/icons/icon7.gif[/img]
If i understand correct ,you suggest snap rolls will stop faster and cleaner because of the extra 10-15 grams from a bigger canopy ? If you calculate the equal in wing tip weight this would be something like 0,3gr or less.
Maybe I didnt understand correct what your are trying to say.
Aerodynamically I think there will be tons of side lift with this fuse and crosswind flying is more crucial.
Thank you either way ! I think canopy looks just fine (and sexy :-)
